[petsc-dev] windows fixes.
Mon Jul 1 15:37:51 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
>         CONFIGURATION CRASH  (Please send configure.log to petsc-maint at mcs.anl.gov)
> 'gcc'  File "/sandbox/petsc/petsc.clone/config/configure.py", line 293, in petsc_configure
>     framework.configure(out = sys.stdout)
>   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/framework.py", line 942, in configure
>     child.configure()
>   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/compilerFlags.py", line 113, in configure
>     self.executeTest(self.configureCompilerFlags)
>   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/base.py", line 126, in executeTest
>     ret = test(*args,**kargs)
>   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/compilerFlags.py", line 97, in configureCompilerFlags
>     flags = options.getCompilerFlags(language, self.setCompilers.getCompiler(), bopt)
>   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/compilerOptions.py", line 212, in getCompilerFlags
>     flags = self.getCFlags(compiler, bopt)
>   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/compilerOptions.py", line 19, in getCFlags
>     if config.setCompilers.Configure.isGNU(compiler) or config.setCompilers.Configure.isClang(compiler):
>   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/util.py", line 68, in __call__
>     return self[args]
What exception is raised?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130701/3296fe37/attachment.sig>
