[petsc-dev] windows fixes.
Wed Jul 3 11:29:00 CDT 2013
How about:
-  isGNU = staticmethod(config.memoize(isGNU))
+  import sys
+  if sys.version_info >= (2,5):
+    isGNU = staticmethod(config.memoize(isGNU))
+  else:
+    isGNU = staticmethod(isGNU)
or
-class memoize(dict):
-    '''Memoizing decorator.  No support for keyword arguments.'''
-    def __init__(self, func):
-        self.func = func
+import sys
+if sys.version_info >= (2,5):
+    class memoize(dict):
+        '''Memoizing decorator.  No support for keyword arguments.'''
+        def __init__(self, func):
+            self.func = func
-    def __call__(self, *args):
-        return self[args]
+        def __call__(self, *args):
+            return self[args]
-    def __missing__(self, args):
-        ret = self[args] = self.func(*args)
-        return ret
+        def __missing__(self, args):
+            ret = self[args] = self.func(*args)
+            return ret
+else:
+    def memoize(dict):
+        return dict
Satish
On Mon, 1 Jul 2013, Satish Balay wrote:
> On Mon, 1 Jul 2013, Jed Brown wrote:
> > Satish Balay <balay at mcs.anl.gov> writes:
> > >         CONFIGURATION CRASH  (Please send configure.log to petsc-maint at mcs.anl.gov)
> > > 'gcc'  File "/sandbox/petsc/petsc.clone/config/configure.py", line 293, in petsc_configure
> > >     framework.configure(out = sys.stdout)
> > >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/framework.py", line 942, in configure
> > >     child.configure()
> > >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/compilerFlags.py", line 113, in configure
> > >     self.executeTest(self.configureCompilerFlags)
> > >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/base.py", line 126, in executeTest
> > >     ret = test(*args,**kargs)
> > >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/compilerFlags.py", line 97, in configureCompilerFlags
> > >     flags = options.getCompilerFlags(language, self.setCompilers.getCompiler(), bopt)
> > >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/compilerOptions.py", line 212, in getCompilerFlags
> > >     flags = self.getCFlags(compiler, bopt)
> > >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/compilerOptions.py", line 19, in getCFlags
> > >     if config.setCompilers.Configure.isGNU(compiler) or config.setCompilers.Configure.isClang(compiler):
> > >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/util.py", line 68, in __call__
> > >     return self[args]
> > What exception is raised?
> I don't know how to check that.
> You can reproduce this on 'cg' by running [on next] ./config/examples/arch-linux-gcc-absoft.py
> Satish
