[petsc-dev] Need mechanism to set LocalToGlobal mapping in a DMShell
Thu Feb 21 12:42:53 CST 2013
It would be natural to have a matching interface, but why do you need it?
You're in charge of making the matrices and vectors so you can give them
local-to-global mappings. The only solver that calls
DMGetLocalToGlobalMapping is PCEXOTIC, which only works with DMDA anyway.
On Thu, Feb 21, 2013 at 12:35 PM, Richard Tran Mills <rtm at eecs.utk.edu>wrote:
> Hi Folks,
> I want to set a LocalToGlobal mapping in a DMShell object.  Should we add
> a DMShell routine to do this, or just add a DMSetLocalToGlobalMapping()
> routine?
> Thanks,
> Richard
> Richard Tran Mills, Ph.D.
> Computational Earth Scientist      | Joint Assistant Professor
> Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
> Oak Ridge National Laboratory      | University of Tennessee, Knoxville
> E-mail: rmills at ornl.gov  V: 865-241-3198 http://climate.ornl.gov/~**rmills<http://climate.ornl.gov/~rmills>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130221/87e69ab0/attachment.html>
