[petsc-dev] Example cleanup
Sun Feb 10 08:49:32 CST 2013
On Sun, Feb 10, 2013 at 8:40 AM, Matthew Knepley <knepley at gmail.com> wrote:
> The phrase "may as well" is very slippery. Python arrays are just [x, y,
> z], whereas JSON needs a library.
> However, the format is is now way crucial to the scheme. I want to get the
> workflow up an running with
> the simplest format. We will inevitably tweak it was we add tons of crap
> on top if it works.
The syntax for plain arrays is identical. I was suggesting JSON to manage
recursive data structures (nested solvers, perhaps monitoring different
things). So it becomes a dict of arrays or a dict of dicts of arrays. Also,
we could spit out -snes_view in machine-readable form, we could have nicer
diagnostics on the GUI side. It is because of these extensions that I think
it's worth starting with something that will extend gracefully rather than
a hack that is only intended for arrays of numbers.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130210/cd78827d/attachment.html>
