[petsc-dev] Example cleanup
Sun Feb 10 08:40:25 CST 2013
On Sun, Feb 10, 2013 at 1:05 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sat, Feb 9, 2013 at 8:04 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>  What's your plan for implementing this?
>> My plan was to try the easiest thing I could think of first:
>>   a) Make a replacement monitor for SNES and KSP
>>       It would have a big honking sentinel before each solve and
>> iterations in Python array format
>>   b) Run a braindead Python parser over this which snips out the monitors
>>   c) Diff the monitor sections with a numerical tolerance
>>   d) Diff the whole thing, and throw out differences in the monitor
>> sections, since we know the line numbers.
>>       Maybe it would be easier to just remove those lines, but we need to
>> experiment a little.
> Okay, so this would all be implemented in C?
Does the Bear(y) shit in the woods?
> If you want Python array format, you may as well use JSON since it's more
> of an exchange standard and it's the most convenient format for monitoring
> in a web-based GUI. There are a bunch of good JSON libraries, ranging from
> the ultra-compact http://zserge.bitbucket.org/jsmn.html and
> http://ccodearchive.net/info/json.html, to the object-oriented
> http://www.digip.org/jansson/doc/dev/tutorial.html.
The phrase "may as well" is very slippery. Python arrays are just [x, y,
z], whereas JSON needs a library.
However, the format is is now way crucial to the scheme. I want to get the
workflow up an running with
the simplest format. We will inevitably tweak it was we add tons of crap on
top if it works.
    Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130210/092a0fef/attachment.html>
