[petsc-dev] macro functions growing like rabbits
Wed Feb 6 22:12:21 CST 2013
On Wed, Feb 6, 2013 at 10:07 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   While I'm busy converting macro functions to C functions, others
> (unnamed, but Jed knows how to find them using the revision control system)
> are adding new ones like there is no tomorrow.
> For example below.
> Yes CPP is unfairly useful and some of the uses below do pass types that
> cannot trivially be handled with pure C code, please try to restrict your
> love of CPP to only when absolutely necessary; for example the first one
> below doesn't need to be a macro I think.
The first example below was added by Barry in 2008 and can soon be deleted.
https://bitbucket.org/petsc/petsc-dev/commits/2c4d80a83ccb656c1ab09c5dcec9c685c121655f
The second is like PetscTryMethod in that it really needs to be a macro.
>    Barry
>       Allocates enough space to store Fortran function pointers in PETSc
> object
>    that are needed by the Fortran interface.
> #define PetscObjectAllocateFortranPointers(obj,N) do {                  \
>     if (!((PetscObject)(obj))->fortran_func_pointers) {                 \
>       *ierr =
> PetscMalloc((N)*sizeof(void(*)(void)),&((PetscObject)(obj))->fortran_func_pointers);if
> (*ierr) return; \
>       *ierr =
> PetscMemzero(((PetscObject)(obj))->fortran_func_pointers,(N)*sizeof(void(*)(void)));if
> (*ierr) return; \
>       ((PetscObject)obj)->num_fortran_func_pointers = (N);              \
>   } while (0)
> /* Entire function body, _ctx is a "special" variable that can be passed
> along */
> #define PetscObjectUseFortranCallback_Private(obj,cid,types,args,cbclass)
>     PetscErrorCode ierr;                                                \
>     void (PETSC_STDCALL *func) types,*_ctx;                             \
>     PetscFunctionBegin;                                                 \
>     ierr =
> PetscObjectGetFortranCallback((PetscObject)(obj),(cbclass),(cid),(PetscVoidFunction*)&func,&_ctx);CHKERRQ(ierr);
>     (*func)args;CHKERRQ(ierr);                                          \
>     PetscFunctionReturn(0);                                             \
> #define PetscObjectUseFortranCallback(obj,cid,types,args)
> PetscObjectUseFortranCallback_Private(obj,cid,types,args,PETSC_FORTRAN_CALLBACK_CLASS)
> #define PetscObjectUseFortranCallbackSubType(obj,cid,types,args)
> PetscObjectUseFortranCallback_Private(obj,cid,types,args,PETSC_FORTRAN_CALLBACK_SUBTYPE)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130206/d5a55973/attachment.html>
