[petsc-dev] macro functions growing like rabbits
Wed Feb 6 22:07:12 CST 2013
  While I'm busy converting macro functions to C functions, others (unnamed, but Jed knows how to find them using the revision control system) are adding new ones like there is no tomorrow.
For example below.
Yes CPP is unfairly useful and some of the uses below do pass types that cannot trivially be handled with pure C code, please try to restrict your love of CPP to only when absolutely necessary; for example the first one below doesn't need to be a macro I think.
   Barry
      Allocates enough space to store Fortran function pointers in PETSc object
   that are needed by the Fortran interface.
#define PetscObjectAllocateFortranPointers(obj,N) do {                  \
    if (!((PetscObject)(obj))->fortran_func_pointers) {                 \
      *ierr = PetscMalloc((N)*sizeof(void(*)(void)),&((PetscObject)(obj))->fortran_func_pointers);if (*ierr) return; \
      *ierr = PetscMemzero(((PetscObject)(obj))->fortran_func_pointers,(N)*sizeof(void(*)(void)));if (*ierr) return; \
      ((PetscObject)obj)->num_fortran_func_pointers = (N);              \
  } while (0)
/* Entire function body, _ctx is a "special" variable that can be passed along */
#define PetscObjectUseFortranCallback_Private(obj,cid,types,args,cbclass) { \
    PetscErrorCode ierr;                                                \
    void (PETSC_STDCALL *func) types,*_ctx;                             \
    PetscFunctionBegin;                                                 \
    ierr = PetscObjectGetFortranCallback((PetscObject)(obj),(cbclass),(cid),(PetscVoidFunction*)&func,&_ctx);CHKERRQ(ierr); \
    (*func)args;CHKERRQ(ierr);                                          \
    PetscFunctionReturn(0);                                             \
#define PetscObjectUseFortranCallback(obj,cid,types,args) PetscObjectUseFortranCallback_Private(obj,cid,types,args,PETSC_FORTRAN_CALLBACK_CLASS)
#define PetscObjectUseFortranCallbackSubType(obj,cid,types,args) PetscObjectUseFortranCallback_Private(obj,cid,types,args,PETSC_FORTRAN_CALLBACK_SUBTYPE)
