[petsc-dev] macro functions growing like rabbits
Wed Feb 6 22:17:33 CST 2013
On Wed, Feb 6, 2013 at 11:12 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Wed, Feb 6, 2013 at 10:07 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   While I'm busy converting macro functions to C functions, others
>> (unnamed, but Jed knows how to find them using the revision control system)
>> are adding new ones like there is no tomorrow.
>> For example below.
>> Yes CPP is unfairly useful and some of the uses below do pass types that
>> cannot trivially be handled with pure C code, please try to restrict your
>> love of CPP to only when absolutely necessary; for example the first one
>> below doesn't need to be a macro I think.
> The first example below was added by Barry in 2008 and can soon be deleted.
> https://bitbucket.org/petsc/petsc-dev/commits/2c4d80a83ccb656c1ab09c5dcec9c685c121655f
Programming languages corrupt. Fortran corrupts absolutely.
   Matt
> The second is like PetscTryMethod in that it really needs to be a macro.
>>    Barry
>>       Allocates enough space to store Fortran function pointers in PETSc
>> object
>>    that are needed by the Fortran interface.
>> #define PetscObjectAllocateFortranPointers(obj,N) do {                  \
>>     if (!((PetscObject)(obj))->fortran_func_pointers) {                 \
>>       *ierr =
>> PetscMalloc((N)*sizeof(void(*)(void)),&((PetscObject)(obj))->fortran_func_pointers);if
>> (*ierr) return; \
>>       *ierr =
>> PetscMemzero(((PetscObject)(obj))->fortran_func_pointers,(N)*sizeof(void(*)(void)));if
>> (*ierr) return; \
>>       ((PetscObject)obj)->num_fortran_func_pointers = (N);              \
>>   } while (0)
>> /* Entire function body, _ctx is a "special" variable that can be passed
>> along */
>> #define PetscObjectUseFortranCallback_Private(obj,cid,types,args,cbclass)
>>     PetscErrorCode ierr;                                                \
>>     void (PETSC_STDCALL *func) types,*_ctx;                             \
>>     PetscFunctionBegin;                                                 \
>>     ierr =
>> PetscObjectGetFortranCallback((PetscObject)(obj),(cbclass),(cid),(PetscVoidFunction*)&func,&_ctx);CHKERRQ(ierr);
>>     (*func)args;CHKERRQ(ierr);                                          \
>>     PetscFunctionReturn(0);                                             \
>> #define PetscObjectUseFortranCallback(obj,cid,types,args)
>> PetscObjectUseFortranCallback_Private(obj,cid,types,args,PETSC_FORTRAN_CALLBACK_CLASS)
>> #define PetscObjectUseFortranCallbackSubType(obj,cid,types,args)
>> PetscObjectUseFortranCallback_Private(obj,cid,types,args,PETSC_FORTRAN_CALLBACK_SUBTYPE)
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130206/c1d92dd7/attachment.html>
