[petsc-dev] Pushing non-working code
Sun Feb 3 11:49:54 CST 2013
On Sun, Feb 3, 2013 at 11:31 AM, Matthew Knepley <knepley at gmail.com> wrote:
> How is _not typing 'hg merge' or 'hg pull'_ harder than typing it? Do your
>> work in a bookmark and merge it when it's ready for review. It's not a hard
>> concept.
> It is clearly more work.
How so? Every (non-science) open source project I've worked with expects
this sort of workflow.
>>>>  There are no "gains" from a baseline. This is
>>>>> a point I have made multiple times. Changes must be justified.
>>>> I provided a long list of justifications that you have not responded
>>>> to. There is a great deal of empirical evidence to back my claims.
>>> I have responded to each and every point carefully. You need to listen.
>> You have not said anything about reviewability, actual bug rates,
>> extensibility, ability to recognize distinct features in the history, or
>> realized and perceived stability and lack of spurious warnings when users
>> pull petsc-dev.
> Reviewability: I have responded that a) you are reviewing at the wrong
> time, and b) your second example was a perfectly reviewable checkin which
> resulted in an easy fix.
> Actual bug rates:  you have not offered any evidence here, so my assertion
> is that they do not decrease
[citation needed]
http://kev.inburke.com/kevin/the-best-ways-to-find-bugs-in-your-code/
http://en.wikipedia.org/wiki/Code_review
http://www.codinghorror.com/blog/2006/01/code-reviews-just-do-it.html
> Extensibility: Your assertion is that extensibility benefits from code
> review. I agree. You are reviewing at the wrong time. Code reviews
> should be organized, not carried out after every checkin.
My view is that the history should _be the organization_. If you want to
organize it differently, please suggest an alternative system.
> Ability to recognize distinct features in history: I do not think this is
> worth preserving at the cost of a lot more process. This is the linux model
> where everything is smoothed out into a series of clean patches. We have
> explicitly chosen not to do this. It obscures the actual development
> process and I am not convinced it is as useful here as they claim in the
> kernel.
The amount of process is proportional to the required stability and number
of developers and users. A bug in kernel 'master' is an extremely bad
thing. Even when fixed the same day, it can cost many thousands of dollars
(it interrupts development for many developers and tends to discourage
early adopters). PETSc is not such critical infrastructure, but I think it
would be good to offer a more reliable low-latency way to interact with
applications, which in turn requires more stability. Also, bugs that make
it into a release are much more expensive than bugs fixed early, even
without counting the indirect effect of discouraging users.
I'm not proposing the full kernel workflow, but having slightly better
feature provenance and encouraging up-front review would be good.
> Warnings: I did respond to that, so its not worth repeating here.
Only that you "try not to".
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130203/2109b56f/attachment.html>
