[petsc-dev] Enabling single precision for MUMPS and SUPERLU
Stefano Zampini stefano.zampini at gmail.com
Fri Sep 21 12:27:37 CDT 2012
Hong, attached please find the two patches split.
2012/9/21 Hong Zhang <hzhang at mcs.anl.gov>
> Stefano:
>> When Hong has finished testing, I will split the patches and commit them.
>> Please let me know what macro name you'll choose (or the ugly choice of
>> course)
> How about split the patches now?
> Then I'll test one package at a time.
> Hong
>> There is also pastix which can be enabled, but the problem is that it
>> requires pt-scotch for partitioning, and in turn pt-scotch will become a
>> possible method to be used in MatPartitioning class. Maybe someone can
>> think about adding a new command line argument in package configure which
>> guaranties you will use a library (pt-scotch) only inside  pastix and not
>> within the MatPartitioning class? (maybe using self.useddirectly in
>> config/BuildSystem/package.py)
>> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120921/bf09c51a/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120921/bf09c51a/attachment.gz>
