[petsc-dev] Enabling single precision for MUMPS and SUPERLU
Hong Zhang hzhang at mcs.anl.gov
Fri Sep 21 10:57:42 CDT 2012
Stefano:
> When Hong has finished testing, I will split the patches and commit them.
> Please let me know what macro name you'll choose (or the ugly choice of
> course)
How about split the patches now?
Then I'll test one package at a time.
Hong
> There is also pastix which can be enabled, but the problem is that it
> requires pt-scotch for partitioning, and in turn pt-scotch will become a
> possible method to be used in MatPartitioning class. Maybe someone can
> think about adding a new command line argument in package configure which
> guaranties you will use a library (pt-scotch) only inside  pastix and not
> within the MatPartitioning class? (maybe using self.useddirectly in
> config/BuildSystem/package.py)
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120921/1fa9b813/attachment.html>
