[petsc-dev] migrating repos from petsc.cs.iit.edu to bitbucket.org
Sat Nov 17 09:59:53 CST 2012
On Fri, 16 Nov 2012, Barry Smith wrote:
> On Nov 16, 2012, at 3:45 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > I think we could nicely do petsc-dev, petsc-release, and one buildsystem managed as a subrepo.
>    I'm willing to try this.
So how do we proceed with it?
- commit buildsystem as subrepo of petsc-release
- reset petsc-release/config/BuildSystem to point to bitbucket/buildsystem
- remove 'auto-clone buildsystem code from petsc-release
- fixup tarball generation code to work with subrepos
- merge with petsc-dev
- abandon buildsystem-release?
[more cleanup in petsc-dev]
- rename BuildSystem -> buildsystem in petsc-dev only?
Do we make sure all commiters to petsc-release have the latest
mercurial? [even subrepo behavior can be different with older
mercurial versions..]
And the workflow for release patches.
- *never do* pull or update in petsc-release/config/BuildSystem
- commit change to petc-release [even if the change is in petsc-release/config/BuildSystem]
- push petsc-release to bitbucket [but the subrepo buildsystem push will fail?]
- merge petsc-release to petsc-dev
- [how does one merge petsc-release/BuildSystem*release-head* to petsc-dev/buildsystem-*head*?]
- push petsc-dev to bitbucket [this should also push petsc-dev/config/buildsystem with
  all changes to bitbucket?]
Satish
