[petsc-dev] migrating repos from petsc.cs.iit.edu to bitbucket.org
Dmitry Karpeev karpeev at mcs.anl.gov
Fri Nov 16 16:00:37 CST 2012
I have been using bookmarks to label subprojects locally and in my forks of
petsc.
Admittedly, that usage was rather pedestrian, but at least at that level
they seemed to be fine.
Dmitry.
On Fri, Nov 16, 2012 at 3:51 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Nov 16, 2012, at 3:45 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > I think we could nicely do petsc-dev, petsc-release, and one buildsystem
> managed as a subrepo.
>    I'm willing to try this.
>    Barry
> > We could do one petsc too, bit hg branches/bookmarks kinda suck so I
> don't think it would be as nice.
> > On Nov 16, 2012 4:32 PM, "Satish Balay" <balay at mcs.anl.gov> wrote:
> > to rephrase - do we do:
> > 1. petsc, buildsystem, petsc-release, buildsystem-release
> > 2. petsc-dev, buildsystem-dev, petsc-release, buildsystem-release
> > 3. petsc-dev, buildsystem, petsc-release, buildsystem-release
> > 4. something else?
> > satish
> > On Fri, 16 Nov 2012, Satish Balay wrote:
> > > Do you want to have the repo name as 'buildsystem' or
> > > 'buildsystem-dev'?
> > > note: reclones shouldn't be need for such renames [or url changes] -
> > > but one is free to do that if they want to..
> > > Satish
> > > On Fri, 16 Nov 2012, Barry Smith wrote:
> > > >   I am not advocating fixing all capitalizations at this time, just
> BuildSystems.
> > > >   Plus we should tell everyone to completely reclone anyways.
> > > >    Keeping the in consist BuildSystem just to prevent a small number
> of temporary hiccups is not a good idea. We're writing PETSc not lapack.
> > > >    Barry
> > > > On Nov 16, 2012, at 2:10 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > > >> On Nov 16, 2012, at 11:14 AM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > > >>> I'm in the process of migrating repos from petsc.cs.iit.edu to
> > > > >>> bitbucket.org, and have to resolve a few organization issues.
> > > > >>> Restrictions.
> > > > >>> - all repos should be lowercase
> > > > >>> - no subdir organization possible [like
> http://petsc.cs.iit.edu/petsc/externalpackages/]
> > > > >>> 1. Since we are forced to change reponame from 'BuildSystem' to
> > > > >>> 'buildsystem' - I'd like to take this opportunity to change it to
> > > > >>> 'buildsystem-dev' to be consistent with petsc-dev. i.e
> instructions
> > > > >>> will be:
> > > > >>> hg clone https://bitbucket.org/petsc/petsc-dev
> > > > >>> hg clone https://bitbucket.org/petsc/buildsystem-devpetsc-dev/config/BuildSystem
> > > > >>> or
> > > > >>> hg clone https://bitbucket.org/petsc/petsc-release
> > > > >>> hg clone https://bitbucket.org/petsc/buildsystem-releasepetsc-release/config/BuildSystem
> > > > >>> and current clones would need updates to .hg/hgrc only.
> > > > >>> one alternative was to change the path in source to
> > > > >>> petsc-dev/config/buildsystem but it will cause some breakage and
> other
> > > > >>> inconsistencies in source file naming scheming - so I'm against
> that
> > > > >>   What breakage. I really don't like having caps in one place and
> small letters in another. Horrible inconsistency
> > > > > I guess one can anticipate all issues and make configure deal with
> > > > > them. [with autofix - or with an error message]. The couple of
> > > > > issues I was thinking off:
> > > > > - different organization between petsc-release and buildsystem
> confusing
> > > > > users.
> > > > > - configure might automatically create a new 'buildsystem' clone -
> when
> > > > > the user might still have BuildSystem - and attempt to make
> changes there.
> > > > > - bisection might need manual tweaking if if needs to go back and
> > > > >  forth over this changepoint [from BuildSystem to buildsystem]
> > > > > Also we won't have consistant naming of 'reop' to 'file' anyway.
> So I
> > > > > see not much motivation to preserve the 'lowercase' part of the
> > > > > attribute.
> > > > > i.e buildsystem-dev -> buildsystem
> > > > >    buildsystem-release -> buildsystem
> > > > > Also with this rename - lot of sourcefiles/dirs have to be renamed
> > > > > [for a consistant lowercase naming scheme] - loosing annotations in
> > > > > mercurial history [perhaps mercurial should handle this
> automatically
> > > > > - but I haven't checked it in depth].
> > > > > Satish
> > > > >>    Barry
> > > > >>> another alternative is to use 'petsc', 'buildsystem',
> 'petsc-release',
> > > > >>> 'buildsystem-release' [but we have too much baggage referring to
> > > > >>> petsc-dev, with a mailing list etc reusing this name]
> > > > >>> 2. I plan to reorganize external package repos [that we might
> have
> > > > >>> patches for] with a pkg prefix.
> > > > >>> i.e
> > > > >>> http://petsc.cs.iit.edu/petsc/externalpackages/metis-5.0.2
> > > > >>> http://petsc.cs.iit.edu/petsc/externalpackages/parmetis-4.0.2
> > > > >>> to:
> > > > >>> https://bitbucket.org/petsc/pkg-metis-5.0.2
> > > > >>> https://bitbucket.org/petsc/pkg-parmetis-4.0.2
> > > > >>> etc..
> > > > >>> 3. Are AMS, ctetgen, win32fe special packages and be listed at
> toplevel?
> > > > >>> currently ctetgen is listed under 'externalpackages'. Should it
> be at toplevel?
> > > > >>> i.e
> > > > >>> https://bitbucket.org/petsc/win32fe-dev
> > > > >>> https://bitbucket.org/petsc/ams-dev
> > > > >>> https://bitbucket.org/petsc/ctetgen-dev
> > > > >>> Any thoughts?
> > > > >>> thanks,
> > > > >>> Satish
Dmitry Karpeev, Ph.D.
Assistant Computational Mathematician
Mathematics and Computer Science
Argonne National Laboratory
Argonne, Illinois, USA
and
Fellow
Computation Institute
University of Chicago
5735 S. Ellis Avenue
Chicago, IL 60637
Phone: 630-252-1229
Fax:   630-252-5986
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121116/03c1f8b5/attachment.html>
