[petsc-dev] Notification: Fwd: You have hereby been granted admin access to jedbrown/petsc-dev.
Dmitry Karpeev karpeev at mcs.anl.gov
Fri Nov 16 15:10:38 CST 2012
On Fri, Nov 16, 2012 at 3:06 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Fri, 16 Nov 2012, Jed Brown wrote:
> > On Fri, Nov 16, 2012 at 2:57 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > >   In petsc-XXX/config/   what will you call BuildSystem?  BuildSystem,
> > > buildsystem, buildsystem-dev, buildsystem-XXX
> > >    It would be nice to have totally consistent naming of the same
> thing in
> > > different places but do we really want petsc-XXX/config/buildsystem-yyy
> > > where
> > > yyy is different depending on release or dev?
> > If we used hg subrepo, each PETSc version would reference a SHA1 from
> > buildsystem. Then we could just have buildsystem. When a patch needed to
> go
> > into "buildsystem-release", we would apply the patch to the buildsystem
> > version that release depends on and update petsc-release to reference
> that
> > SHA1, independent of the existence of post-release patches (only relevant
> > to petsc-dev) in the buildsystem repository.
> And the next step is to just have 'petsc' and 'buildsystem' repos [no
> petsc-release] to fix a different inconsistancy [1 for buildsystem, 2
> for petsc-dev]
+1
Dmitry.
> and then 'petsc' only [and no buildsystem]?
> Wrt your suggestion - I guess it would work at the cost of extra
> complexity wrt workflow.
> Satish
Dmitry Karpeev, Ph.D.
Assistant Computational Mathematician
Mathematics and Computer Science
Argonne National Laboratory
Argonne, Illinois, USA
and
Fellow
Computation Institute
University of Chicago
5735 S. Ellis Avenue
Chicago, IL 60637
Phone: 630-252-1229
Fax:   630-252-5986
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121116/7395a019/attachment.html>
