[petsc-dev] Notification: Fwd: You have hereby been granted admin access to jedbrown/petsc-dev.
Fri Nov 16 15:06:27 CST 2012
On Fri, 16 Nov 2012, Jed Brown wrote:
> On Fri, Nov 16, 2012 at 2:57 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   In petsc-XXX/config/   what will you call BuildSystem?  BuildSystem,
> > buildsystem, buildsystem-dev, buildsystem-XXX
> >    It would be nice to have totally consistent naming of the same thing in
> > different places but do we really want petsc-XXX/config/buildsystem-yyy
> > where
> > yyy is different depending on release or dev?
> If we used hg subrepo, each PETSc version would reference a SHA1 from
> buildsystem. Then we could just have buildsystem. When a patch needed to go
> into "buildsystem-release", we would apply the patch to the buildsystem
> version that release depends on and update petsc-release to reference that
> SHA1, independent of the existence of post-release patches (only relevant
> to petsc-dev) in the buildsystem repository.
And the next step is to just have 'petsc' and 'buildsystem' repos [no
petsc-release] to fix a different inconsistancy [1 for buildsystem, 2
for petsc-dev]
and then 'petsc' only [and no buildsystem]?
Wrt your suggestion - I guess it would work at the cost of extra
complexity wrt workflow.
Satish
