[petsc-dev] Regression Tests for petsc-dev
Jed Brown five9a2 at gmail.com
Sat May 19 21:43:31 CDT 2012
You can run "make alltest" if you like.
On May 19, 2012 9:38 PM, "Dave Nystrom" <dnystrom1 at comcast.net> wrote:
> I'm interested in doing more extensive tests of my build of petsc-dev than
> what I get from doing a "make test" after the build.  Would running the
> petsc-dev regression test suite be the right thing to consider?  If so, how
> would I run the regression test suite after a build of petsc-dev?
> Thanks,
> Dave
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120519/5abb273c/attachment.html>
