[petsc-dev] Regression Tests for petsc-dev
Dave Nystrom dnystrom1 at comcast.net
Sat May 19 14:53:35 CDT 2012
I'm interested in doing more extensive tests of my build of petsc-dev than
what I get from doing a "make test" after the build.  Would running the
petsc-dev regression test suite be the right thing to consider?  If so, how
would I run the regression test suite after a build of petsc-dev?
Dave
