[petsc-dev] Regression Tests for petsc-dev
Dave Nystrom dnystrom1 at comcast.net
Sat May 19 22:28:46 CDT 2012
Thanks.  I'll try that.
Jed Brown writes:
 > You can run "make alltest" if you like.
 > On May 19, 2012 9:38 PM, "Dave Nystrom" <dnystrom1 at comcast.net> wrote:
 > > I'm interested in doing more extensive tests of my build of petsc-dev than
 > > what I get from doing a "make test" after the build.  Would running the
 > > petsc-dev regression test suite be the right thing to consider?  If so, how
 > > would I run the regression test suite after a build of petsc-dev?
 > > Thanks,
 > > Dave
