[petsc-dev] Spelling Chebyshev
Thu May 10 15:22:10 CDT 2012
On Thu, May 10, 2012 at 3:19 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Jed :
>> This rename needs to be documented in dev.html.
>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/9ffb4f0fe85d
> Pushed.
>> Should we register both spellings (they are both used, though Chebyshev
>> is more common).
> I do not see Chebychev is being used. Good search ' Chebychev' fails as
> well.
484,000 results on google.
http://en.wikipedia.org/wiki/Pafnuty_Chebyshev
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120510/266c46e1/attachment.html>
