[petsc-dev] Spelling Chebyshev
Hong Zhang hzhang at mcs.anl.gov
Thu May 10 15:19:59 CDT 2012
Jed :
> This rename needs to be documented in dev.html.
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/9ffb4f0fe85d
Pushed.
> Should we register both spellings (they are both used, though Chebyshev is
> more common).
I do not see Chebychev is being used. Good search ' Chebychev' fails as
well.
Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120510/0d1f4b03/attachment.html>
