[petsc-dev] Spelling Chebyshev
Thu May 10 14:11:29 CDT 2012
This rename needs to be documented in dev.html.
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/9ffb4f0fe85d
Should we register both spellings (they are both used, though Chebyshev is
more common).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120510/8b225713/attachment.html>
