[petsc-dev] What needs to be done before a release?
Sat May 5 21:32:53 CDT 2012
On Fri, May 4, 2012 at 12:57 PM, Peter Brune <prbrune at gmail.com> wrote:
> Jed, what else needs to be done with respect to getting all the SNEScontext into DM?  I notice that, for instance, SNESSet/GetFunction is still
> mostly using the ops in SNES rather than the ones in SNESDM.
I had a temporary option -snes_kspcompute to make the dispatch go through
SNESDM. The main holdup now is -snes_grid_sequence, but I'm banging away at
ex48 again, so I should be able to get it all working shortly. (I have ex48
running without DMMG, but some functionality is missing now, like changing
the physics in the middle of the MG hierarchy.)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120505/c038f5cd/attachment.html>
