[petsc-dev] What needs to be done before a release?
Peter Brune prbrune at gmail.com
Fri May 4 13:57:38 CDT 2012
Jed, what else needs to be done with respect to getting all the SNES
context into DM?  I notice that, for instance, SNESSet/GetFunction is still
mostly using the ops in SNES rather than the ones in SNESDM.
- Peter
On Wed, May 2, 2012 at 12:02 PM, Blaise Bourdin <bourdin at lsu.edu> wrote:
> Barry,
> >> Also, fortran wrappers over PetscOptionsEnum and PetscBagRegisterEnum
> would be nice. I understand that it
> >> is a bit tricky since it involves passing fortran arrays of strings.
> >     Yup. We'd be willing to support these from FORTRAN but someone else
> has to do the dirty work of figuring out how to handle those array of
> strings (maybe F2003?).
> I am attaching a simple proof of concept example that demonstrates how to
> write a fortran interface and call petsc C functions from fortran using
> F2003 C-interoperability instead of going through the fortran bindings.
> Don't be put off by all the warnings if you use gfortran. They would be
> easy to avoid. Basically, right now, you detect the fortran integer and
> real kinds that match that of the C ones. It would be quite simple to get
> the fortran C-interoperable integer and real types associated with the C
> type of PetscInt, PetscReal etc.
> Basically, we (I?) could write a fortran interface and a fortran function
> for the tricky functions involving arrays of string, instead of creating a
> custom binding in C. Are you willing to let some fortran pollution into the
> petsc code? Where would these function have to be?
> Blaise
> PS: you need FCFLAGS='-ffixed-line-length-none  -ffree-line-length-none
> -ffree-form' or some subset of these to compile with gfortran. I'm not sure
> why these are not the default with a file suffix .F90
> Department of Mathematics and Center for Computation & Technology
> Louisiana State University, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
> http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120504/3200efab/attachment.html>
