[petsc-dev] passing a function pointer?
Thu May 3 21:44:30 CDT 2012
On May 3, 2012, at 9:33 PM, Cinstance wrote:
> I am using PETSC as the linear solver for a CFD project. It is part of an integrated frame work, and the project is developed under MS Windows.
> I use PETSC as prebuild libs in Visual Studio, so I cannot debug into PETSC code (at least for now I haven't figured out how to).
   You should be able to build the debug version of PETSc on WINDOWS then in visual studio you can just debug down to the PETSc routines.
> What make it worse is that the framework ignored all the PetscPrintf messages. This leaves me in total darkness.
  Hope this helps.
http://www.mcs.anl.gov/petsc/documentation/faq.html#redirectstdout
> The framework has its own printf derived method. Is there a way to pass it as a function pointer to petsc for it to use for printing stuff. Does it have a way to pass on this?
> Thanks,
> Lesong
