[petsc-dev] passing a function pointer?
Cinstance cinstance at gmail.com
Fri May 4 12:30:22 CDT 2012
Thanks for the relies. I tried to generate VS projects via CMAKE, but got
the following error:
CMake Error: The source "C:/cygwin/home/Lesong/petsc-dev/CMakeLists.txt"
does not match the source "/home/Lesong/petsc-dev/CMakeLists.txt" used to
generate cache. Re-run cmake with a different source directory
Do I need to use a cygwin remapped directory instead of the default one to
build the cmake configuration?
Thanks again,
Lesong
On Thu, May 3, 2012 at 10:44 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On May 3, 2012, at 9:33 PM, Cinstance wrote:
> > I am using PETSC as the linear solver for a CFD project. It is part of
> an integrated frame work, and the project is developed under MS Windows.
> > I use PETSC as prebuild libs in Visual Studio, so I cannot debug into
> PETSC code (at least for now I haven't figured out how to).
>    You should be able to build the debug version of PETSc on WINDOWS then
> in visual studio you can just debug down to the PETSc routines.
> > What make it worse is that the framework ignored all the PetscPrintf
> messages. This leaves me in total darkness.
>   Hope this helps.
> http://www.mcs.anl.gov/petsc/documentation/faq.html#redirectstdout
> > The framework has its own printf derived method. Is there a way to pass
> it as a function pointer to petsc for it to use for printing stuff. Does it
> have a way to pass on this?
> > Thanks,
> > Lesong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120504/f0bb7345/attachment.html>
