[petsc-dev] Partial build
John Fettig john.fettig at gmail.com
Wed May 2 16:01:46 CDT 2012
To answer my own question, it looks like you have to use libfast, not lib.
John
On Wed, May 2, 2012 at 4:54 PM, John Fettig <john.fettig at gmail.com> wrote:
> If I modify src/vec/vec/impls/seq/seqcusp/veccusp.cu and then (in that
> directory) type "make lib", shouldn't it rebuild the library?  I have also
> tried "make ACTION=lib tree" from higher up, and it still doesn't rebuild.
>  What's the secret?  This works for .c files.
> Thanks,
> John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120502/e9723378/attachment.html>
