[petsc-dev] Partial build
Satish Balay
balay at mcs.anl.gov
Wed May 2 16:02:50 CDT 2012
Normally both should work. Looks like 'lib' is broken.
Satish
On Wed, 2 May 2012, John Fettig wrote:
> To answer my own question, it looks like you have to use libfast, not lib.
> John
> On Wed, May 2, 2012 at 4:54 PM, John Fettig <john.fettig at gmail.com> wrote:
> > If I modify src/vec/vec/impls/seq/seqcusp/veccusp.cu and then (in that
> > directory) type "make lib", shouldn't it rebuild the library? I have also
> > tried "make ACTION=lib tree" from higher up, and it still doesn't rebuild.
> > What's the secret? This works for .c files.
> > Thanks,
> > John
