[petsc-dev] Partial build
John Fettig john.fettig at gmail.com
Wed May 2 15:54:02 CDT 2012
If I modify src/vec/vec/impls/seq/seqcusp/veccusp.cu and then (in that
directory) type "make lib", shouldn't it rebuild the library?  I have also
tried "make ACTION=lib tree" from higher up, and it still doesn't rebuild.
 What's the secret?  This works for .c files.
John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120502/5cd26af0/attachment.html>
