[petsc-dev] API changes in MatIS
Mon Jun 11 10:56:50 CDT 2012
On Mon, Jun 11, 2012 at 9:11 AM, Stefano Zampini
<stefano.zampini at gmail.com>wrote:
> thus the Mat should have a public flag indicating Assembly or not at
> preselected vertices during MatAssembly?
Part of the Mat configuration would be to select vertices for assembly. If
you don't select any, then none would be assembled.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120611/fadab68c/attachment.html>
