[petsc-dev] Fwd: [petsc-maint #119133] petsc-dev configure crash
Thu Jun 7 15:30:50 CDT 2012
On Thu, 7 Jun 2012, Satish Balay wrote:
> Another issue:
> I make edits to both petsc-dev and BuildSystem. But before commiting I
> can usually do 'hg pull -u' in each repo [for the usual automerge
> case]
> With subrepo - without commits/changes - I can do 'hg pull -u' and it
> goes recursively.  But if I do the same with local edits [not commits]
> - I get the following:
> [So I should know the state of buildsystem - before invoking 'hg pull
> -u' in petsc-dev - and use it only if no changes in BuildSystem?]
> Satish
> [balay at maverick petsc-buildsystem-dev]$ hg st -S
> [balay at maverick petsc-buildsystem-dev]$ hg -q in -S
> 23599:7c0333892302
> 23600:007d9928edc8
> 2828:1c53f750b541
> 2829:6548b4f26bd1
> 2830:03ab1f7aeb3a
> 2831:6ab6f1ae4aff
> [balay at maverick petsc-buildsystem-dev]$ vi config/examples/asterix/asterix64.py config/BuildSystem/config/packages/BlasLapack.py
> 2 files to edit
> M config/BuildSystem/config/packages/BlasLapack.py
> M config/examples/asterix/asterix64.py
> [balay at maverick petsc-buildsystem-dev]$ hg pull -u
> running ssh petsc at petsc.cs.iit.edu 'hg -R /home/petsc/petsc-buildsystem-dev serve --stdio'
> pulling from ssh://petsc@petsc.cs.iit.edu//home/petsc/petsc-buildsystem-dev
> searching for changes
> all local heads known remotely
> adding changesets
> adding manifests
> adding file changes
> added 2 changesets with 3 changes to 2 files
> resolving manifests
> running ssh petsc at petsc.cs.iit.edu 'hg -R /home/petsc/BuildSystem-subrepo serve --stdio'
> pulling subrepo config/BuildSystem from ssh://petsc@petsc.cs.iit.edu//home/petsc/BuildSystem-subrepo
> adding changesets
> adding manifests
> adding file changes
> added 4 changesets with 4 changes to 4 files
>  subrepository sources for config/BuildSystem differ
> use (l)ocal source (eadaa286b5ca) or (r)emote source (6ab6f1ae4aff)?
Ok  - I have to choose 'r' here for what I want [wrt diff/auto-merge].
[balay at maverick petsc-buildsystem-dev]$ hg stat -S
M .hgsubstate
But for some reason '.hgsubstate' is not updated [to correspond to 'hg pull -u' version].
Hm..
Satish
