[petsc-dev] Fwd: [petsc-maint #119133] petsc-dev configure crash
Thu Jun 7 14:43:29 CDT 2012
Another issue:
I make edits to both petsc-dev and BuildSystem. But before commiting I
can usually do 'hg pull -u' in each repo [for the usual automerge
case]
With subrepo - without commits/changes - I can do 'hg pull -u' and it
goes recursively.  But if I do the same with local edits [not commits]
- I get the following:
[So I should know the state of buildsystem - before invoking 'hg pull
-u' in petsc-dev - and use it only if no changes in BuildSystem?]
Satish
[balay at maverick petsc-buildsystem-dev]$ hg st -S
[balay at maverick petsc-buildsystem-dev]$ hg -q in -S
23599:7c0333892302
23600:007d9928edc8
2828:1c53f750b541
2829:6548b4f26bd1
2830:03ab1f7aeb3a
2831:6ab6f1ae4aff
[balay at maverick petsc-buildsystem-dev]$ vi config/examples/asterix/asterix64.py config/BuildSystem/config/packages/BlasLapack.py
2 files to edit
M config/BuildSystem/config/packages/BlasLapack.py
M config/examples/asterix/asterix64.py
[balay at maverick petsc-buildsystem-dev]$ hg pull -u
running ssh petsc at petsc.cs.iit.edu 'hg -R /home/petsc/petsc-buildsystem-dev serve --stdio'
pulling from ssh://petsc@petsc.cs.iit.edu//home/petsc/petsc-buildsystem-dev
searching for changes
all local heads known remotely
adding changesets
adding manifests
adding file changes
added 2 changesets with 3 changes to 2 files
resolving manifests
running ssh petsc at petsc.cs.iit.edu 'hg -R /home/petsc/BuildSystem-subrepo serve --stdio'
pulling subrepo config/BuildSystem from ssh://petsc@petsc.cs.iit.edu//home/petsc/BuildSystem-subrepo
adding changesets
adding manifests
adding file changes
added 4 changesets with 4 changes to 4 files
 subrepository sources for config/BuildSystem differ
use (l)ocal source (eadaa286b5ca) or (r)emote source (6ab6f1ae4aff)?
