[petsc-dev] Fwd: [petsc-maint #119133] petsc-dev configure crash
Thu Jun 7 14:21:00 CDT 2012
On Thu, 7 Jun 2012, Jed Brown wrote:
> On Thu, Jun 7, 2012 at 1:28 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > ok - rebase behaves differently with subrepos. How is it supporsed to work?
> > With separate repos - I can do:
> > hg commit [local changes]
> > hg pull --rebase  [automatically rebases the commit
> > hg push
> The rebase is not applied recursively in subrepos. Compare what we have now:
> remember to go into config/BuildSystem, pull, merge or rebase, and push
> to how it works with sebrepos:
> If you naively pull, but there is a subrepo conflict, it will error. That
> tells you that you have to go into config/BuildSystem, pull, and merge.
> Once you do that and commit to petsc, BuildSystem will automatically be
> carried along on subsequent pushes, etc.
Right now - with 2 repos - I can use rebase [in both repos separately]
But if we switch to subrepos - then I can't use rebase - and always
use merge?
Satish
[balay at maverick petsc-buildsystem-dev]$ hg commit -S
committing subrepository config/BuildSystem
config/packages/BlasLapack.py
.hgsubstate
config/examples/asterix/asterix64.py
committed changeset 23599:a9a8d40da950
[balay at maverick petsc-buildsystem-dev]$ hg push
pushing to ssh://petsc@petsc.cs.iit.edu//home/petsc/petsc-buildsystem-dev
running ssh petsc at petsc.cs.iit.edu 'hg -R /home/petsc/petsc-buildsystem-dev serve --stdio'
pushing subrepo config/BuildSystem to ssh://petsc@petsc.cs.iit.edu//home/petsc/BuildSystem-subrepo
running ssh petsc at petsc.cs.iit.edu 'hg -R /home/petsc/BuildSystem-subrepo serve --stdio'
searching for changes
new remote heads on branch 'default'
new remote head 2bb21b50ee60
abort: push creates new remote head 2bb21b50ee60!
(you should pull and merge or use push -f to force)
[balay at maverick petsc-buildsystem-dev]$ cd config/BuildSystem/
[balay at maverick BuildSystem]$ hg pull --rebase
pulling from ssh://petsc@petsc.cs.iit.edu//home/petsc/BuildSystem-subrepo
adding changesets
adding manifests
adding file changes
added 4 changesets with 4 changes to 4 files (+1 heads)
resolving manifests
getting config/packages/BlasLapack.py
getting config/setCompilers.py
getting jeff
getting joe
getting urlMappingLocal.py
resolving manifests
rebase merging completed
1 changesets found
saved backup bundle to /home/balay/petsc-buildsystem-dev/config/BuildSystem/.hg/strip-backup/2bb21b50ee60-backup.hg
5 changesets found
adding branch
adding changesets
adding manifests
adding file changes
added 5 changesets with 5 changes to 5 files
rebase completed
[balay at maverick BuildSystem]$ cd ../..
[balay at maverick petsc-buildsystem-dev]$ hg pull --rebase
abort: uncommitted changes in subrepo config/BuildSystem
[balay at maverick petsc-buildsystem-dev]$ hg st -S
warning: error "unknown revision '2bb21b50ee6020c5a8608742da2b0c8da0212510'" in subrepository "config/BuildSystem"
>>>>>>>>>>. ok - perhaps the rebase in buildsystem means - a new commit in petsc-buildsystem-dev? <<<<<<<<
.hgsubstate
committed changeset 23600:cd90aa80d97d
pulling from ssh://petsc@petsc.cs.iit.edu//home/petsc/petsc-buildsystem-dev
sampling from both directions
adding changesets
adding manifests
adding file changes
added 2 changesets with 3 changes to 2 files (+1 heads)
resolving manifests
getting .hgsubstate
resolving manifests
getting config/examples/asterix/asterix64.py
getting makefile
resolving manifests
pulling subrepo config/BuildSystem from ssh://petsc@petsc.cs.iit.edu//home/petsc/BuildSystem-subrepo
no changes found
abort: unknown revision '2bb21b50ee6020c5a8608742da2b0c8da0212510'!
[balay at maverick petsc-buildsystem-dev]$ ls config/packages/BlasLapack.py
ls: cannot access config/packages/BlasLapack.py: No such file or directory
[balay at maverick petsc-buildsystem-dev]$ hg -q heads
23602:007d9928edc8
23600:cd90aa80d97d
>>>>>>>>>>. ok - perhaps BuildSystem should never be rebased <<<<<<<<<<<<<<<<<
