[petsc-dev] Fwd: [petsc-maint #119133] petsc-dev configure crash
Wed Jun 6 23:15:34 CDT 2012
On Wed, 6 Jun 2012, Barry Smith wrote:
> >>   Satish,
> >>     You will not just "recheck this". Please setup the petsc-buildsystem-dev test repository so EVERYONE can test it and make sure there are no kinks.
> > Added.
> > ssh://petsc@petsc.cs.iit.edu//home/petsc/petsc-buildsystem-dev
>    Thanks
> barry-smiths-macbook-pro:petsc-buildsystem-dev barrysmith$ hg commit
> abort: uncommitted changes in subrepo config/BuildSystem
> (use --subrepos for recursive commit)
> This is good.
> I don't like the fact that running hg in the subrepo only affects that subrepo (because I generally just run hg in whatever strange place I am and assume it is going to do the right thing). I think running it in that subrepo directory should behave the same as outside it. For example
> If I do
> barry-smiths-macbook-pro:petsc-buildsystem-dev barrysmith$ cd config/BuildSystem/
> barry-smiths-macbook-pro:BuildSystem barrysmith$ touch joe
> barry-smiths-macbook-pro:BuildSystem barrysmith$ hg add joe
> adding joe
> barry-smiths-macbook-pro:BuildSystem barrysmith$ hg commit
> joe
> committed changeset 2830:03ab1f7aeb3a
> barry-smiths-macbook-pro:BuildSystem barrysmith$ hg push
> pushing to ssh://petsc@petsc.cs.iit.edu//home/petsc/BuildSystem-subrepo
> running ssh petsc at petsc.cs.iit.edu 'hg -R /home/petsc/BuildSystem-subrepo serve --stdio'
> searching for changes
> 1 changesets found
> remote: adding changesets
> remote: adding manifests
> remote: adding file changes
> remote: added 1 changesets with 1 changes to 1 files
> or instead do this
> barry-smiths-macbook-pro:BuildSystem barrysmith$ cd ..
> barry-smiths-macbook-pro:config barrysmith$ touch BuildSystem/jeff
> barry-smiths-macbook-pro:config barrysmith$ hg add BuildSystem/jeff
> adding BuildSystem/jeff
> barry-smiths-macbook-pro:config barrysmith$ hg commit
> barry-smiths-macbook-pro:config barrysmith$ hg commit -S
> committing subrepository config/BuildSystem
> jeff
> .hgsubstate
> committed changeset 23600:007d9928edc8
> barry-smiths-macbook-pro:config barrysmith$ hg push
> pushing to ssh://petsc@petsc.cs.iit.edu//home/petsc/petsc-buildsystem-dev
> running ssh petsc at petsc.cs.iit.edu 'hg -R /home/petsc/petsc-buildsystem-dev serve --stdio'
> pushing subrepo config/BuildSystem to ssh://petsc@petsc.cs.iit.edu//home/petsc/BuildSystem-subrepo
> 1 changesets found
> 1 changesets found
> and then take a week vacation.     In the first case if someone else does hg pull in the the petsc-dev they don't get my joe file (which may be like totally needed now to use PETSc) they get all pissed off and send me email that I don't answer for a week. (Yes they could go into BuildSystem and pull but they won't think to do that).
Yes - all of us would have to be conscious of the subrepo model - and
where we are commiting - and what hg is saying after 'hg commit'.
[for ex: is .hgsubstate is updated in the commit as expected or not]
And in this case where you push to only buildsytem - Jed and Peter
would notice this immediately on their RSS feed and add a
build-system-sync-commit to petsc-dev. [If they miss it] -folks like
me would notice it when I make commits to BuildSystem - and have push
errors [or use my old habbit of 'make pull'] - and then would do this
build-system-sync-commit and push.
Satish
>   Am I missing understanding something. Any option in hg to get hg commands inside the subrepo behave like ones on the outside?
>    Barry
> > Just to clarify - this is a play-repo - i.e all edits/clones should be
> > discarded later on.
> > [I'm not sure how one would enforce this - and not have someone mix
> > commits between this repo and the regular petsc-dev So for now its not
> > available at http://]
> > Satish
