[petsc-dev] Regression tests
Thu Jul 26 15:00:07 CDT 2012
On Thu, Jul 26, 2012 at 2:49 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Jul 26, 2012 at 2:44 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> You do not read it correctly. It operates exactly as everything else. You
>> move make.log to make.log.bkp, which is what we do now, and
>> write into make.log. It seems to be writing without moving first.
>>> I think it is wrong to reuse the name make.log for both purposes.
>>> Regardless, the symlinks are not removed, so make.log output overwrites
>>> $PETSC_ARCH/conf/make.log and (the next time you run it)
>>> $PETSC_ARCH/conf/make.log.bkp.
>> In my first message, it says "this is a bug". What is hard about that?
>> What necessitates 3 replies missing that point?
> Sounds like your "correct behavior" is exactly what I'm complaining about.
> Since there is only one level of backup, running twice, as in
> ./builder2.py buildExample src/...
> destroys all trace of the make.log for the library.
How can your make.log go away if its in PETSC_ARCH/conf ? Is this a useful
argument?
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120726/7a67f90f/attachment.html>
