[petsc-dev] Regression tests
Thu Jul 26 15:05:35 CDT 2012
On Thu, Jul 26, 2012 at 3:00 PM, Matthew Knepley <knepley at gmail.com> wrote:
> How can your make.log go away if its in PETSC_ARCH/conf ? Is this a useful
> argument?
The symlinks point there. The way it has always worked is that the symlinks
point at the latest PETSC_ARCH/conf/ and the files there get overwritten
(with one level of backup). Are you saying the symlink should sometimes
gets removed and sometimes the normal file gets deleted and replaced by a
symlink? I think that's confusing.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120726/9a1e0726/attachment.html>
