[petsc-dev] Regression tests
Thu Jul 26 14:49:43 CDT 2012
On Thu, Jul 26, 2012 at 2:44 PM, Matthew Knepley <knepley at gmail.com> wrote:
> You do not read it correctly. It operates exactly as everything else. You
> move make.log to make.log.bkp, which is what we do now, and
> write into make.log. It seems to be writing without moving first.
>> I think it is wrong to reuse the name make.log for both purposes.
>> Regardless, the symlinks are not removed, so make.log output overwrites
>> $PETSC_ARCH/conf/make.log and (the next time you run it)
>> $PETSC_ARCH/conf/make.log.bkp.
> In my first message, it says "this is a bug". What is hard about that?
> What necessitates 3 replies missing that point?
Sounds like your "correct behavior" is exactly what I'm complaining about.
Since there is only one level of backup, running twice, as in
./builder2.py buildExample src/...
destroys all trace of the make.log for the library.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120726/d17e6d57/attachment.html>
