[petsc-dev] PetscOptionsInsertFile_YAML
Blaise Bourdin bourdin at lsu.edu
Thu Jan 19 10:12:50 CST 2012
Nevermind: src/sys/yaml/yamlimpls.c has not been touched since changeset d3065a573ab0 when it was first committed. I upgraded to this changeset and still could not get it to parse a trivial file. Too bad...
Blaise
> OK. Knowing that it used to work is already a god thing. Do you happen to have a vague idea of the last time it worked?
> Just use Aug 1st and test. Who knows, maybe there has always been a bug in the code? I haven't had time to test your example at all because I'm too busy with research at the moment.
> Time for me to learn how to use hg dissect...
> It's `hg bisect` and here is the faq that deals with using bisection on PETSc:
> http://www.mcs.anl.gov/petsc/documentation/faq.html#bisect
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120119/9fdad037/attachment.html>
