[petsc-dev] PetscOptionsInsertFile_YAML
Sean Farley sean at mcs.anl.gov
Wed Jan 18 23:31:04 CST 2012
> OK. Knowing that it used to work is already a god thing. Do you happen to
> have a vague idea of the last time it worked?
Just use Aug 1st and test. Who knows, maybe there has always been a bug in
the code? I haven't had time to test your example at all because I'm too
busy with research at the moment.
Time for me to learn how to use hg dissect...
It's `hg bisect` and here is the faq that deals with using bisection on
PETSc:
http://www.mcs.anl.gov/petsc/documentation/faq.html#bisect
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120118/5d195b85/attachment.html>
