[petsc-dev] PetscOptionsInsertFile_YAML
Thu Jan 19 10:18:14 CST 2012
On Thu, Jan 19, 2012 at 10:12, Blaise Bourdin <bourdin at lsu.edu> wrote:
> Nevermind: src/sys/yaml/yamlimpls.c has not been touched since
> changeset d3065a573ab0 when it was first committed. I upgraded to this
> changeset and still could not get it to parse a trivial file. Too bad...
It usually helps to provide test cases (e.g here is the "trivial file" and
here is the failure output). It sounds like Sean says it worked for some
tests when it was committed, in which case it's not "known to not work"
code.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120119/af9a7bc9/attachment.html>
