[petsc-dev] last update information in PETSc non-generated web pages?
Thu Jan 19 09:28:28 CST 2012
On Tue, Jan 17, 2012 at 11:35, Sean Farley <sean at mcs.anl.gov> wrote:
> Also, I noticed that Jed's merge:
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/979fc00e3fe7
> deleted some of the website changes I made. I can fix these later.
I think you are just misinterpreting the asymmetric diff (hg could be more
helpful about showing it), run
hg diff -r b31388b8e95e..979fc00e3fe7
The only web changes were my updates to linearsolvertable.html, but those
did not undo any of your changes.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120119/80e99621/attachment.html>
