[petsc-dev] last update information in PETSc non-generated web pages?
Tue Jan 17 13:32:18 CST 2012
On Jan 17, 2012, at 11:35 AM, Sean Farley wrote:
> Are there any tricks/ways in Mecurial to have it put at the upper right corner of the webpages that are edited manually the last change date?
> I guess you mean adding a hook to mercurial to have a script do this.
   Whatever it takes.
   Barry
> Also, I noticed that Jed's merge:
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/979fc00e3fe7
> deleted some of the website changes I made. I can fix these later.
