[petsc-dev] last update information in PETSc non-generated web pages?
Sean Farley sean at mcs.anl.gov
Tue Jan 17 11:35:15 CST 2012
> Are there any tricks/ways in Mecurial to have it put at the upper right
> corner of the webpages that are edited manually the last change date?
I guess you mean adding a hook to mercurial to have a script do this. Also,
I noticed that Jed's merge:
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/979fc00e3fe7
deleted some of the website changes I made. I can fix these later.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120117/2337cb63/attachment.html>
