[petsc-dev] boomerAmg scalability
Mark F. Adams mark.adams at columbia.edu
Thu Jan 12 22:03:26 CST 2012
Ravi, can you run with -ksp_view_binary? This will produce two files.
Hong, ex10 will read in these files and solve them.  I will probably not be able to get to this until Monday.
Also, this matrix has just two equations on proc 0 and and about 11000 on proc 1 so its is strangely balanced, in case that helps ...
On Jan 12, 2012, at 10:35 PM, Hong Zhang wrote:
> Ravi,
> I need more info for debugging. Can you provide a simple stand alone code and matrices in petsc
> binary format that reproduce the error?
> MatTransposeMatMult() for mpiaij is a newly developed subroutine - less than one month old
> and not well tested yet :-(
> I used petsc-dev/src/mat/examples/tests/ex94.c for testing.
> Thanks,
> Hong
> On Thu, Jan 12, 2012 at 9:17 PM, Mark F. Adams <mark.adams at columbia.edu> wrote:
> It looks like the problem is in MatTransposeMatMult and Hong (cc'ed) is working on it.
> I'm hoping that your output will be enough for Hong to figure this out but I could not reproduce this problem with any of my tests.
> If Hong can not figure this out then we will need to get the matrix from you to reproduce this.
> Mark
> On Jan 12, 2012, at 6:25 PM, Ravi Kannan wrote:
>> Hi Mark,
>> Any luck with the gamg bug fix?
>> Thanks,
>> Ravi.
>> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Mark F. Adams
>> Sent: Wednesday, January 11, 2012 1:54 PM
>> To: For users of the development version of PETSc
>> Subject: Re: [petsc-dev] boomerAmg scalability
>> This seems to be dying earlier than it was last week, so it looks like a new bug in MatTransposeMatMult.
>> Mark
>> On Jan 11, 2012, at 1:59 PM, Matthew Knepley wrote:
>> On Wed, Jan 11, 2012 at 12:23 PM, Ravi Kannan <rxk at cfdrc.com> wrote:
>> Hi Mark,
>> I downloaded the dev version again. This time, the program crashes even earlier. Attached is the serial and parallel info outputs.
>> Could you kindly take a look.
>> It looks like this is a problem with MatMatMult(). Can you try to reproduce this using KSP ex10? You put
>> your matrix in binary format and use -pc_type gamg. Then you can send us the matrix and we can track
>> it down. Or are you running an example there?
>>   Thanks,
>>     Matt
>> Thanks,
>> Ravi.
>> Sent: Monday, January 09, 2012 3:08 PM
>> Yes its all checked it, just pull from dev.
>> Mark
>> On Jan 9, 2012, at 2:54 PM, Ravi Kannan wrote:
>> Hi Mark,
>> Thanks for your efforts.
>> Do I need to do the install from scratch once again? Or some particular files (check out gamg.c for instance)?
>> Thanks,
>> Ravi.
>> Sent: Friday, January 06, 2012 10:30 AM
>> I think I found the problem.  You will need to use petsc-dev to get the fix.
>> Mark
>> On Jan 6, 2012, at 8:55 AM, Mark F. Adams wrote:
>> Ravi, I forgot but you can just use -ksp_view_binary to output the matrix data (two files).  You could run it with two procs and a Jacobi solver to get it past the solve, where it writes the matrix (I believe).
>> Mark
>> On Jan 5, 2012, at 6:19 PM, Ravi Kannan wrote:
>> Just send in another email with the attachment.
>> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Jed Brown
>> Sent: Thursday, January 05, 2012 5:15 PM
>> On Thu, Jan 5, 2012 at 17:12, Ravi Kannan <rxk at cfdrc.com> wrote:
>> I have attached the verbose+info outputs for both the serial and the parallel (2 partitions). NOTE: the serial output at some location says PC=Jacobi! Is it implicitly converting the PC to a Jacobi?
>> Looks like you forgot the attachment.
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120112/4b936656/attachment.html>
