[petsc-dev] boomerAmg scalability
Ravi Kannan rxk at cfdrc.com
Fri Jan 13 11:16:07 CST 2012
Hi Mark,Hong
Thanks for the observation w.r.t the proc 0 having 2 equations. This is a
bug from our end. We will fix it and get back to you if needed.
Ravi.
From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov]
On Behalf Of Mark F. Adams
Sent: Thursday, January 12, 2012 10:03 PM
To: Hong Zhang
Cc: For users of the development version of PETSc
Subject: Re: [petsc-dev] boomerAmg scalability
Ravi, can you run with -ksp_view_binary? This will produce two files.
Hong, ex10 will read in these files and solve them.  I will probably not be
able to get to this until Monday.
Also, this matrix has just two equations on proc 0 and and about 11000 on
proc 1 so its is strangely balanced, in case that helps ...
On Jan 12, 2012, at 10:35 PM, Hong Zhang wrote:
Ravi,
I need more info for debugging. Can you provide a simple stand alone code
and matrices in petsc
binary format that reproduce the error?
MatTransposeMatMult() for mpiaij is a newly developed subroutine - less than
one month old
and not well tested yet :-(
I used petsc-dev/src/mat/examples/tests/ex94.c for testing.
Hong
On Thu, Jan 12, 2012 at 9:17 PM, Mark F. Adams <mark.adams at columbia.edu>
wrote:
It looks like the problem is in MatTransposeMatMult and Hong (cc'ed) is
working on it.
I'm hoping that your output will be enough for Hong to figure this out but I
could not reproduce this problem with any of my tests.
If Hong can not figure this out then we will need to get the matrix from you
to reproduce this.
On Jan 12, 2012, at 6:25 PM, Ravi Kannan wrote:
Hi Mark,
Any luck with the gamg bug fix?
Ravi.
Sent: Wednesday, January 11, 2012 1:54 PM
To: For users of the development version of PETSc
This seems to be dying earlier than it was last week, so it looks like a new
bug in MatTransposeMatMult.
On Jan 11, 2012, at 1:59 PM, Matthew Knepley wrote:
On Wed, Jan 11, 2012 at 12:23 PM, Ravi Kannan <rxk at cfdrc.com> wrote:
Hi Mark,
I downloaded the dev version again. This time, the program crashes even
earlier. Attached is the serial and parallel info outputs.
Could you kindly take a look.
It looks like this is a problem with MatMatMult(). Can you try to reproduce
this using KSP ex10? You put
your matrix in binary format and use -pc_type gamg. Then you can send us the
matrix and we can track
it down. Or are you running an example there?
    Matt
Ravi.
Sent: Monday, January 09, 2012 3:08 PM
Yes its all checked it, just pull from dev.
On Jan 9, 2012, at 2:54 PM, Ravi Kannan wrote:
Hi Mark,
Thanks for your efforts.
Do I need to do the install from scratch once again? Or some particular
files (check out gamg.c for instance)?
Ravi.
Sent: Friday, January 06, 2012 10:30 AM
I think I found the problem.  You will need to use petsc-dev to get the fix.
On Jan 6, 2012, at 8:55 AM, Mark F. Adams wrote:
Ravi, I forgot but you can just use -ksp_view_binary to output the matrix
data (two files).  You could run it with two procs and a Jacobi solver to
get it past the solve, where it writes the matrix (I believe).
On Jan 5, 2012, at 6:19 PM, Ravi Kannan wrote:
Just send in another email with the attachment.
On Behalf Of Jed Brown
Sent: Thursday, January 05, 2012 5:15 PM
On Thu, Jan 5, 2012 at 17:12, Ravi Kannan <rxk at cfdrc.com> wrote:
I have attached the verbose+info outputs for both the serial and the
parallel (2 partitions). NOTE: the serial output at some location says
PC=Jacobi! Is it implicitly converting the PC to a Jacobi?
Looks like you forgot the attachment.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120113/6959216e/attachment.html>
