[petsc-dev] boomerAmg scalability
Hong Zhang hzhang at mcs.anl.gov
Thu Jan 12 21:35:38 CST 2012
Ravi,
I need more info for debugging. Can you provide a simple stand alone code
and matrices in petsc
binary format that reproduce the error?
MatTransposeMatMult() for mpiaij is a newly developed subroutine - less
than one month old
and not well tested yet :-(
I used petsc-dev/src/mat/examples/tests/ex94.c for testing.
Hong
On Thu, Jan 12, 2012 at 9:17 PM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> It looks like the problem is in MatTransposeMatMult and Hong (cc'ed) is
> working on it.
> I'm hoping that your output will be enough for Hong to figure this out but
> I could not reproduce this problem with any of my tests.
> If Hong can not figure this out then we will need to get the matrix from
> you to reproduce this.
> Mark
> On Jan 12, 2012, at 6:25 PM, Ravi Kannan wrote:
> Hi Mark,****
> Any luck with the gamg bug fix?****
> Thanks,****
> Ravi.****
> *From:* petsc-dev-bounces at mcs.anl.gov [mailto:
> petsc-dev-bounces at mcs.anl.gov] *On Behalf Of *Mark F. Adams
> *Sent:* Wednesday, January 11, 2012 1:54 PM
> *To:* For users of the development version of PETSc
> *Subject:* Re: [petsc-dev] boomerAmg scalability****
> This seems to be dying earlier than it was last week, so it looks like a
> new bug in MatTransposeMatMult.****
> Mark****
> On Jan 11, 2012, at 1:59 PM, Matthew Knepley wrote:****
> On Wed, Jan 11, 2012 at 12:23 PM, Ravi Kannan <rxk at cfdrc.com> wrote:****
> Hi Mark,****
> I downloaded the dev version again. This time, the program crashes even
> earlier. Attached is the serial and parallel info outputs.****
> Could you kindly take a look.****
> It looks like this is a problem with MatMatMult(). Can you try to
> reproduce this using KSP ex10? You put****
> your matrix in binary format and use -pc_type gamg. Then you can send us
> the matrix and we can track****
> it down. Or are you running an example there?****
>   Thanks,****
>     Matt****
> Thanks,****
> Ravi.****
> *Sent:* Monday, January 09, 2012 3:08 PM****
> Yes its all checked it, just pull from dev.****
> Mark****
> On Jan 9, 2012, at 2:54 PM, Ravi Kannan wrote:****
> Hi Mark,****
> Thanks for your efforts.****
> Do I need to do the install from scratch once again? Or some particular
> files (check out gamg.c for instance)?****
> Thanks,****
> Ravi.****
> *Sent:* Friday, January 06, 2012 10:30 AM
> I think I found the problem.  You will need to use petsc-dev to get the
> fix.****
> Mark****
> On Jan 6, 2012, at 8:55 AM, Mark F. Adams wrote:****
> Ravi, I forgot but you can just use -ksp_view_binary to output the matrix
> data (two files).  You could run it with two procs and a Jacobi solver to
> get it past the solve, where it writes the matrix (I believe).****
> Mark****
> On Jan 5, 2012, at 6:19 PM, Ravi Kannan wrote:****
> Just send in another email with the attachment.****
> petsc-dev-bounces at mcs.anl.gov] *On Behalf Of *Jed Brown
> *Sent:* Thursday, January 05, 2012 5:15 PM
> On Thu, Jan 5, 2012 at 17:12, Ravi Kannan <rxk at cfdrc.com> wrote:****
> I have attached the verbose+info outputs for both the serial and the
> parallel (2 partitions). NOTE: the serial output at some location says
> PC=Jacobi! Is it implicitly converting the PC to a Jacobi?****
> Looks like you forgot the attachment.****
> experiments lead.
> -- Norbert Wiener****
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120112/fe84d368/attachment.html>
