[petsc-dev] DMComplex and PCFieldSplit
Fri Feb 24 14:26:02 CST 2012
On Fri, Feb 24, 2012 at 2:23 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> We need a richer field interface. Some way for a client of DM to discover
> vector and tensor structure. Possibly also (eventually) a way to solve
> equations of state so that we can formulate reduced problems in
> non-conservative variables.
I have fields, and numbers of field components. That is not enough to do
what you suggest, but I don't
think that is necessary. We do not need to know the different between a
vector and pseudo-vector, etc.
I think we just need sizes.
  Matt
> On Feb 24, 2012 2:19 PM, "Matthew Knepley" <knepley at gmail.com> wrote:
>> On Fri, Feb 24, 2012 at 1:58 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/518ff70e8a0a
>>> Matt, I want to get rid of these conditionals, not add more. We should
>>> have a DM base interface for getting fields on which to split, that common
>>> interface should _replace_ the DMComposite specialization.
>> I agree. However, I won't put anything in until I do it by hand once.
>> Also, I was tempted to just promote DMGetGlobalISes(), but its not quite
>> right. I am planning
>> to put the IS method in PetscSection. I am hoping eventually DMDA uses
>> PetscSection for
>> layout.
>>    Matt
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120224/4c0af43a/attachment.html>
