[petsc-dev] DMComplex and PCFieldSplit
Fri Feb 24 14:23:40 CST 2012
We need a richer field interface. Some way for a client of DM to discover
vector and tensor structure. Possibly also (eventually) a way to solve
equations of state so that we can formulate reduced problems in
non-conservative variables.
On Feb 24, 2012 2:19 PM, "Matthew Knepley" <knepley at gmail.com> wrote:
> On Fri, Feb 24, 2012 at 1:58 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/518ff70e8a0a
>> Matt, I want to get rid of these conditionals, not add more. We should
>> have a DM base interface for getting fields on which to split, that common
>> interface should _replace_ the DMComposite specialization.
> I agree. However, I won't put anything in until I do it by hand once.
> Also, I was tempted to just promote DMGetGlobalISes(), but its not quite
> right. I am planning
> to put the IS method in PetscSection. I am hoping eventually DMDA uses
> PetscSection for
> layout.
>    Matt
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120224/23f35d2d/attachment.html>
