[petsc-dev] DMComplex and PCFieldSplit
Fri Feb 24 14:19:54 CST 2012
On Fri, Feb 24, 2012 at 1:58 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/518ff70e8a0a
> Matt, I want to get rid of these conditionals, not add more. We should
> have a DM base interface for getting fields on which to split, that common
> interface should _replace_ the DMComposite specialization.
I agree. However, I won't put anything in until I do it by hand once.
Also, I was tempted to just promote DMGetGlobalISes(), but its not quite
right. I am planning
to put the IS method in PetscSection. I am hoping eventually DMDA uses
PetscSection for
layout.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120224/72e59896/attachment.html>
