[petsc-dev] Intel compilers + CUDA
John Fettig john.fettig at gmail.com
Fri Feb 24 11:06:56 CST 2012
On Fri, Feb 24, 2012 at 11:56 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> for one I mistyped the option - it should be: --with-cudac='nvcc -ccbin
> icc'
> But then - should it not be c++? [as cuda internally uses g++ - not gcc].
> So
> --with-cudac='nvcc -ccbin icpc'.
> But this gives me all kinds of wierd errors in configure.log.. Maybe
> it won't work [with intel compilers]..
CUDA .cu files are written in C with some extensions (that are handled by
nvcc and not the passed compiler), so I think you have to use a C
compiler.  You can't write C++ in a .cu file.
John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120224/cbc81160/attachment.html>
