[petsc-dev] Intel compilers + CUDA
Fri Feb 24 10:56:28 CST 2012
for one I mistyped the option - it should be: --with-cudac='nvcc -ccbin icc'
But then - should it not be c++? [as cuda internally uses g++ - not gcc]. So
--with-cudac='nvcc -ccbin icpc'.
But this gives me all kinds of wierd errors in configure.log.. Maybe
it won't work [with intel compilers]..
Satish
On Fri, 24 Feb 2012, John Fettig wrote:
> Unfortunately it doesn't work.  I'll send the logs to petsc-maint, but
> here's the error.  If you remove these lines:
> #ifndef PETSC_HAVE___INT64
> #define PETSC_HAVE___INT64 1
> #endif
> from $PETSC_ARCH/include/petscconf.h, it builds ok (and make test passes).
> Here's the error:
> nvcc -O -arch=sm_20 -c --compiler-options=-fPIC
> -I/home/jfe/local/petsc-dev/include
> -I/home/jfe/local/petsc-dev/intel-opt-cuda-precise/include
> -I/usr/local/cuda/include
> -I/home/jfe/local/petsc-dev/intel-opt-cuda-precise/include/txpetscgpu/include
> -I/usr/local/encap/platform_mpi-8.01/include
> -D__INSDIR__=src/vec/vec/impls/seq/seqcusp/ veccusp.cu
> /home/jfe/local/petsc-dev/include/petscsys.h(219): error: identifier
> "__int64" is undefined
> John
> On Fri, Feb 24, 2012 at 10:53 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > --compiler-bindir <directory>               (-ccbin)
> >        Specify the directory in which the compiler executable (Microsoft
> >        Visual Studion cl, or a gcc derivative) resides. By default, this
> >        executable is expected in the current executable search path.
> > It says it will look for the default compiler in the specified path -
> > and doesn't mention that it can switch the compiler. Ah - the manpage
> > is misleading.. Looks like '--ccbin icc' works..
> > balay at bb30:~/junk>nvcc -v -ccbin icc sizeof.c
> > #$ _SPACE_=
> > #$ _CUDART_=cudart
> > #$ _HERE_=/usr/local/cuda/bin
> > #$ _THERE_=/usr/local/cuda/bin
> > #$ _TARGET_SIZE_=64
> > #$ TOP=/usr/local/cuda/bin/..
> > LD_LIBRARY_PATH=/usr/local/cuda/bin/../lib:/usr/local/cuda/bin/../extools/lib:/soft/intel/11.0.081/lib/intel64:/soft/intel/11.0.081/lib/intel64:/usr/local/cuda/lib64:/usr/local/cuda/lib64
> > PATH=/usr/local/cuda/bin/../open64/bin:/usr/local/cuda/bin:/soft/intel/11.0.081/bin/intel64:/soft/intel/11.0.081/bin/intel64:/usr/mpi/gcc/mvapich2-1.5/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/cuda/bin:/usr/local/cuda/bin
> > #$ INCLUDES="-I/usr/local/cuda/bin/../include"
> > "-I/usr/local/cuda/bin/../include/cudart"
> > #$ LIBRARIES=  "-L/usr/local/cuda/bin/../lib64" -lcudart
> > #$ CUDAFE_FLAGS=
> > #$ OPENCC_FLAGS=
> > #$ PTXAS_FLAGS=
> > #$ icc -c -x c "-I/usr/local/cuda/bin/../include"
> > "-I/usr/local/cuda/bin/../include/cudart"   -m64 -o
> > "/tmp/tmpxft_00000199_00000000-1_sizeof.o" "sizeof.c"
> > #$ icpc -m64 -o "a.out" -Wl,--start-group
> > "-L/usr/local/cuda/bin/../lib64" -lcudart -Wl,--end-group
> > So '--with-cc=icc' --with-nvcc='nvcc --ccbin icc' should work.. Will
> > check..
> > Satish
> > > Some time ago I asked about using icc with nvcc.  You can use icc with
> > nvcc
> > > by passing it as an argument:
> > > nvcc -ccbin /path/to/icc
> > > Has anybody tried building PETSc with CUDA this way?
> > > John
